Запчасти
Никакие детали не требуются.
  1. Flip the phone over to have the rear cover facing up.
    • Flip the phone over to have the rear cover facing up.
      • The camera lens should be towards the top of the phone.
  2. Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Slide the cover up, towards the top of phone, to unlock the battery cover.
    • Lift the cover off phone and remove it.
    • Use your finger to push the top of the battery downwards and lift the battery out of the phone.
    • Remove the six Torx #5 screws that are securing the rear frame.
    • Pry the frame open, releasing the eight plastic tabs around the edge of the frame, using the plastic opening tool.
      • A plastic card can be used instead of the plastic opening tool.
    • Remove the single Phillips #0 screw that is securing the motherboard to the front case of the phone.
    • Pry the motherboard away from the front of the plastic case using a plastic opening tool.
      • Be careful not to break the ribbon cable when prying away the motherboard.
    • Remove the plastic cover from the LCD display and the motherboard.
      • The Motherboard and the LCD are still attached together.
    • Remove the gray tape securing the ribbon cable.
    • Remove the yellow tape securing the connector lock.
    • Carefully lift the black lock to release the ribbon cable, using the plastic opening tool.
    • Pull the ribbon cable upwards, disconnecting it from the Motherboard.
    • Lift the Motherboard away from the LCD display.
    • Lift off main keyboard from front plastic case using plastic opening tool.
    • Remove four Phillips #00 screws securing function keys.
    • Pop keys out by pushing keys from back of the phone.
Заключение
Marco Jokada
Участник с: 28.04.2011
247 Репутация
Автор 6 руководств
Команда
CSU Los Angeles, Team 1-2, Nelson Spring 2011 Member of CSU Los Angeles, Team 1-2, Nelson Spring 2011
CSULA-NELSON-S11S1G2
5 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,659
