HTC Radar 4G Battery Replacement
Выберете то, что вам нужно
  1. HTC Radar 4G Battery Replacement, Slide off the back panel: шаг 1, изображение 1 из 2 HTC Radar 4G Battery Replacement, Slide off the back panel: шаг 1, изображение 2 из 2
    • Slide off the white back panel.
    • This is the time to remove the SIM card, so remove it now.
    Спросите у FixBot
    Добавить комментарий
  2. HTC Radar 4G Battery Replacement, Remove the motherboard protector screws: шаг 2, изображение 1 из 1
    • Remove the 4 silver T5 Torx screws from the motherboard protector.
    • Some screws may be stuck in. If so, use a pair of tweezers to carefully remove them from their holes.
    Спросите у FixBot
  3. HTC Radar 4G Battery Replacement, Slide off the rear motherboard protector: шаг 3, изображение 1 из 1
    • Carefully slide off the motherboard protector.
    • This may take some force if this is the first time opening the phone.
    • Take care not to apply too much downward force, because you may accidentally damage the sensitive components on the motherboard.
    Спросите у FixBot
  4. HTC Radar 4G Battery Replacement, Remove the frame screws: шаг 4, изображение 1 из 1
    • Remove the 2 black T5 Torx screws from the silver frame.
    • Make sure to not accidentally slip the screwdriver, because you may break sensitive components on the motherboard.
    Спросите у FixBot
  5. HTC Radar 4G Battery Replacement, Remove the casing: шаг 5, изображение 1 из 1
    • Gently push on the motherboard until the display starts to come out of its frame.
    • Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
    • Remember, do this carefully. We don't want to end up with a dead motherboard.
    Спросите у FixBot
  6. HTC Radar 4G Battery Replacement, Remove the battery: шаг 6, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    iFixit Opening Picks (Set of 6)
    $4.95
    • Use a fingernail or an opening pick to lift the battery out of its slot.
    • Insert the opening pick on the right side at the top for best results.
    • Once it is at about a 30-degree angle, pull up on the battery to disconnect it.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Calibrate your new battery for optimal performance.Take your e-waste to an R2 or e-Stewards certified recycler.
Еще один человек закончил это руководство.
hellonearth311
Участник с: 03/30/24
390 Репутация
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 22
За всё время: 346
