Fix Your Stuff
Right to Repair
Parts & Tools
Введение
Removing the battery is an essential step in opening up the phone.
  1. First, flip the phone over so that the back is facing you.
    • First, flip the phone over so that the back is facing you.
  2. Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone. Set this piece aside until you need to   reassemble the phone.
    • Next, using both thumbs, carefully push the back side of the phone's exterior up, removing it from the main section of the phone.
    • Set this piece aside until you need to reassemble the phone.
  3. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside. Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
    • Insert thumb and pointer finger into the notch above the battery. Pull the battery away from the rest of the phone and set it aside.
Заключение
Luke Plewa
Участник с: 22.04.2011
116 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 25-29, Garner Spring 2011 Участник Cal Poly, Team 25-29, Garner Spring 2011
CPSU-GARNER-S11S25G29
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,867
