Fix Your Stuff
Right to Repair
Parts & Tools
Введение
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Запчасти
Детали не указаны.
  1. Remove the back panel by sliding it up.
    • Remove the back panel by sliding it up.
  2. Remove the battery.
    • Remove the battery.
  3. Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. Use the plastic opening tool to remove the front panel from the phone. Unplug the front button cable from the inside of the phone.
    • Use the plastic opening tool to remove the front panel from the phone.
    • Unplug the front button cable from the inside of the phone.
  5. Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
    • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  6. Seperate the motherboard from the black plastic casing. Unplug the black and red wire from the motherboard.
    • Seperate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  7. Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
    • Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
  8. Remove the camera lens from the motherboard using the plastic opening tool.
    • Remove the camera lens from the motherboard using the plastic opening tool.
Заключение
Еще один человек закончил это руководство.
Sehyun
Участник с: 31.03.2011
57 Репутация
1 руководство автора
Команда
Cal Poly, Team 15-12, Regan Spring 2011 Участник Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,539
