Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Apply pressure and slide upward to remove back cover.
Lift the back cover up away from the phone.
Lift battery upward on the upper right-hand side to remove it.
Check the battery to make sure there's no bent corners
Using a T-5 screwdriver head, remove the four screws in corners as shown.
Lift the part shown in picture 2 on the top side of the phone.
There is a ribbon attached on the back of this part that requires caution to remove.
Use the tweezers to pull up and off the camera cover.
Use the tweezers to pull up and the off camera.
Еще один человек закончил это руководство.
