Отремонтируйте ваше устройство
Обучение ремонту
Магазин
  1. Remove the back cover by applying pressure and sliding upward. Lift the back cover up and away from the phone. Lift the back cover up and away from the phone.
    • Remove the back cover by applying pressure and sliding upward.
    • Lift the back cover up and away from the phone.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  3. Remove the battery by lifting upward from the slot located on the right hand side. Remove the battery by lifting upward from the slot located on the right hand side.
    • Remove the battery by lifting upward from the slot located on the right hand side.
  4. Insert stylus into black slot and gentle pry SIM card out a little bit. Slide out SIM card rest of the way with your finger. Slide out SIM card rest of the way with your finger.
    • Insert stylus into black slot and gentle pry SIM card out a little bit.
    • Slide out SIM card rest of the way with your finger.
Заключение
Еще один человек закончил это руководство.
Melinda Phan
Участник с: 17.04.2011
435 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 9-64, Walters Spring 2011 Участник Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 членов
Автор 9 руководств
Один комментарий
how to change language to English
onlyisaac4real - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 6,704
