Введение
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
Выберете то, что вам нужно
Insert a spudger or a plastic opening tool into the seam on the side of the phone.
Gently pry apart the two halves of the phone.
Gently unplug the connectors.
Remove the screws with a 00 Phillips-head screwdriver.
Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
Remove the 4 screws by using a 00 Phillips-head screwdriver.
Gently lift the connectors.
Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
3 человек успешно провели ремонт по этому руководству.
