Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
Выберете то, что вам нужно
Insert a spudger or a plastic opening tool into the seam on the side of the phone.
Gently pry apart the two halves of the phone.
Gently unplug the connectors.
Remove the screws with a 00 Phillips-head screwdriver.
Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
Remove the 4 screws by using a 00 Phillips-head screwdriver.
Gently lift the connectors.
Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
3 участников успешно повторили данное руководство.
