Введение
This guide will show you how to replace the HTC Trophy display. The display shows all the functions of the phone.
Indications that a new display may be needed:
- the screen will not light up
- the screen is cracked
- the screen or part of the screen will only show one color
- the screen is unresponsive to touch
Once the screen is replaced, handle with care as there may be sharp edges caused by damage.
Выберете то, что вам нужно
Power off the phone before starting.
Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
Apply a small force towards the bottom of the phone and lift upwards.
Remove the 5 screws holding the two phone halves together.
Three 4mm long T5 Torx screws.
Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
One 4mm long Philips #000 screw.
Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
Remove the three screws holding the mother board to the display assembly.
One 2mm long Philips #000 screw.
Two 4mm long T5 Torx screws in the holes of the plastic.
Use the iFixit opening tool to separate the motherboard from the display assembly.
Еще один человек закончил это руководство.
