Введение
The HTC Vive controller motherboard may be damaged and not able to function. The motherboard is crucial for all functions of the remote. This guide will show you how to replace the motherboard.
Выберете то, что вам нужно
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
Remove only the top saucer cover by pulling up with your hand.
Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
Gently lift the right side of the panel to the left.
Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
Use the nylon spudger to lift the white tab by 90 degrees.
Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
Use the nylon spudger to rotate the black tab up by 90 degrees.
Disconnect the ribbon cable carefully with your finger.
9 участников успешно повторили данное руководство.
13 Комментариев
Hi, do you know where I can get a new motherboard? I bought my controller second hand and after several months it stoppedworking…. when I took it apart the connection at the bottom has been removed and two wires soldered in place but it’s so small I can’t do it again so I need a new motherboard
thanks
I am looking for the connetor at step 10. The top of the connector is broken (fail quality assurence). I am not interrested to purchase a new controler at 200$ because of a 2 cents connector.
Thank you
I had the same connector problem in step 10, where can I just buy the mother board
did either of you find the connector for the power button to mother board in step 10
