Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
The HTC Vive controller motherboard may be damaged and not able to function. The motherboard is crucial for all functions of the remote. This guide will show you how to replace the motherboard.
Запчасти
Детали не указаны.
  1. Turn over the Vive controller so that the bottom saucer is facing up. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer. Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Where can I buy new t5 21 mm screws? Mine are getting stripped out!
    jeremyvanwoerden - Ответить
  2. Use the nylon spudger to separate the top and bottom saucer covers all around the edges. Remove only the top saucer cover by pulling up with your hand.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    My top saucer was REALLY stubborn. Don’t force it with your hand, use the spudger to separate it at the seam. Try not to poke your spudger in too deep, there are internals just inside the seam.
    trevorsklar - Ответить
    The second time around, I learned why it was so stubborn. The picture suggests that you should start at the base of the saucer and work your way around, but that’s backwards.
    Start separating with your spudger at the distal side of the saucer and work your way toward the handle. Then for the last part, pull the piece up and away, like peeling a banana. See the second picture for the bottom half of the saucer, below. Do the same on the top.
  3. Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel. Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    It’s Phillips 0, not 00.
    You do not need to remove these screws to remove the bottom saucer. They provide stability to the two halves of the donut.
    pacoavocado - Ответить
    I had the same experience. Putting the screws back in made the bottom shell easier to remove.
    Nate Plamondon - Ответить
  4. Carefully pull away the bottom saucer cover with your hand. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking. To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    I found the re-assembly of this difficult until I concentrated on two areas - the lugs which go into the handle first, then the central ring. My earlier concern was for the optical sensors on the wings but these snapped into place easily as the central ring was manoeuvred.
    Doug - Ответить
  5. Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel. Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
  6. Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    Leave the middle screw where it is (the one being unscrewed in the picture). That screw holds the two halves of the photodiode assembly together, not the case.
    five screws… two at bottom
    andrew sauter - Ответить
  7. Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle. Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
  8. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  9. Disconnect the upper ribbon cable gently by pulling the ribbon up and  away from the motherboard with two fingers.
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    You do not have to remove the ribbon cables from the plugs…you can carefully work the battery holder around them and remove it…being very gentle. And the black part of the handle will stay attached to the cables and be in the way. But removing the cables does make it easier to access the area for the battery, just not completely necessary.
    controll - Ответить
  10. Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers. Do not try to disconnect the ribbon cables from the front panel.
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    where can one buy the ribbon cable.
    Luigi Munoz - Ответить
  11. Use the nylon spudger to lift  the white tab by 90 degrees. Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers. Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
  12. Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate. Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
  13. Remove the silver plate by pinching it with two fingers and lifting up.
    • Remove the silver plate by pinching it with two fingers and lifting up.
    There is no plate on mine, only tape covering it.
    tamgoddess - Ответить
  14. Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
  15. Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame. Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    On my controller these were Philips 000 5.8mm screws, the same as in the previous step.
    Daan Steenmeijer - Ответить
    Second the above with a slight correction. Phillips 00.
  16. Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up. Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
  17. Lift the battery frame to remove the battery from the Vive controller Lift the battery frame to remove the battery from the Vive controller Lift the battery frame to remove the battery from the Vive controller
    • Lift the battery frame to remove the battery from the Vive controller
  18. Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
    These should be the silver screws not the black screws
    Thomas Edwards - Ответить
    Yeah, I think he switched the bottom battery screws with these in a previous disassembly. (see my comment at step 14) I’m opening mine for the first time since new purchase and the motherboard has 4 T5 screws.
  19. Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard. Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
  20. Use the nylon spudger to rotate the black tab up by 90 degrees. Disconnect the ribbon cable carefully with your finger. Disconnect the ribbon cable carefully with your finger.
    • Use the nylon spudger to rotate the black tab up by 90 degrees.
    • Disconnect the ribbon cable carefully with your finger.
  21. Lift the motherboard up and out of the Vive controller using your hands. Lift the motherboard up and out of the Vive controller using your hands. Lift the motherboard up and out of the Vive controller using your hands.
    • Lift the motherboard up and out of the Vive controller using your hands.
    what is the benefit of the rectangular silver steel or ironic metal ,that iside the htc vive hand controller.?????
    is it to solve some issus with the Mpu6500 sensor ??
    or related to get rid of interferrences ??
    the rectanguler metal piece is near to the mother board and the battery in the following image :-
    https://d3nevzfk7ii3be.cloudfront.net/ig...
    Thanks in advance!
    Moatazzu993 - Ответить
    I believe it’s just a weight to help balance the controller by shifting the center of gravity closer to the rear/bottom end. It doesn’t connect to anything, and the board has its own shield. So, just a slab of metal.
    Jeff Suovanen -
Заключение
5 участников успешно повторили данное руководство.
Christopher Amaro
Участник с: 16.10.2017
706 Репутация
Автор 5 руководств
Команда
Cal Poly, Team S15-G5, Livingston Fall 2017 Участник Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 членов
Автор 8 руководств
Комментариев: 9
Hi, do you know where I can get a new motherboard? I bought my controller second hand and after several months it stoppedworking…. when I took it apart the connection at the bottom has been removed and two wires soldered in place but it’s so small I can’t do it again so I need a new motherboard
thanks
nick.bentley.france - Ответить
I am looking for the connetor at step 10. The top of the connector is broken (fail quality assurence). I am not interrested to purchase a new controler at 200$ because of a 2 cents connector.
Thank you
Yahveh Me - Ответить
I had the same connector problem in step 10, where can I just buy the mother board
Adam Vosburgh -
what plug is the for the bottom of the mother board for the main button looking to replace in step 10
angeloro - Ответить
I’m have a problem with step 10 too)
where I can buy new motherboard or how I can fix this ?
my connector in step 10 was broken
Folomieiev - Ответить
Thanksgiving, bu I think I’ll just get a new one.
Chunkiest Boy - Ответить
Where can i get controller motherboard, just had a problem on mine. HELP. thanks
jozell Castillo - Ответить
Another broken step 10 conector here
Nicolás Victorero Mier - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 22
За последние 30 дней: 152
За всё время: 4,684
