Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn over the Vive controller so that the bottom saucer is facing up.
Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
Remove only the top saucer cover by pulling up with your hand.
Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
Carefully pull away the bottom saucer cover with your hand.
6 участников успешно повторили данное руководство.
3 Комментариев
Where do you get the replacement parts?
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
