Введение
How to replace the battery on HTC 8S.
Выберете то, что вам нужно
Видео обзор
Switch off the phone.
Remove the SIM / memory card cover.
Remove any SIM and memory cards.
Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
Use a plastic tool and slowly separate the back cover.
The loudspeaker is inside on the back cover.
Use a Phillips #0 screwdriver and remove the 4x silver screws.
With a plastic tool carefully separate the battery from the logic board.
The battery connector is under the middle frame. Remove it and disconnect the battery.
Model: BM59100 / 3,8VDC / 1700mAh
3 участников успешно повторили данное руководство.
