Введение
By removing the back plate and disconnecting the bus for the camera, replacing it isn't difficult.
Выберете то, что вам нужно
Power the phone off.
Use your thumb to gently press downward and away from the camera to remove the battery cover.
Use a plastic opening tool to remove the camera cover.
Lift the camera cover off of the phone.
Remove the stylus from the phone.
Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
Lift the back case off completely.
