Введение
This guide will explain how to install / remove the receiver on the HTC Wizard 200.
Выберете то, что вам нужно
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
Once the rear panel is loose, lift it off of the front panel.
The flexible connection will pop loose.
Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
Unscrew the two 3mm phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
