Введение
Takes you through the steps to install the vibrator.
Выберете то, что вам нужно
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
Почти готово!
Заключение
