Введение
This guide demonstrates the procedure for replacing a faulty camera in the HTC myTouch 3G.
  1. Press each thumb on both sides of the upper corners and apply pressure downwards.
    • Press each thumb on both sides of the upper corners and apply pressure downwards.
    • Then, while still applying pressure, slide the back cover down.
  2. Remove the Battery.
    • Remove the Battery.
    • Remove the SIM card.
    • Push the SD card in and the SD card should pop loose.
    • Pull the SD card out.
    • Remove the four 6-mm T5 torx screws in the four corners.
    • Remove the two 4-mm T5 torx screws in the middle.
    • Use the existing gap, to dislodge the antenna cover from the phone.
    • Pull out the antenna cover to have access to the motherboard.
    • Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward.
    • Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
    • Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
    • Place a finger between the circuit board and the front cover, and lift up gently.
    • Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach.
    • Finish separating the circuit board from the front panel.
    • Turn the piece housing the circuit boards over to the side with the mounted camera.
    • Remove the three 3-mm Phillips head screws located on the top circuit board.
    • Locate the ribbon cable on the top circuit board.
    • Disconnect the ribbon cable by using a precision screwdriver to flip open the ribbon cable.
    • Locate the two wired connections on the top circuit board.
    • Remove the wired connections by using a squeeze-and-pull action.
    • Slowly lift the circuit board from the left.
    • Continue to flip the circuit board all the way over to the right.
    • The other side of the camera and circuit board should be exposed.
    • Disconnect the ribbon cable with a precision screwdriver.
    • Remove the faulty camera and replace with a new one.
Заключение
Tony Tran
Участник с: 25.09.2012
366 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 2-9, Propen Fall 2012 Member of Cal Poly, Team 2-9, Propen Fall 2012
CPSU-PROPEN-F12S2G9
3 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,348
