Введение
The Huawei Fit comes equipped with a spring loaded rubber strap. This guide will show the steps necessary to remove the strap for replacement with any 22mm spring loaded strap.
Выберете то, что вам нужно
Insert the metal spudger tool into the outer edge of the latch component.
Hold the watch securely and press the spring latch component towards you with the metal spudger tool.
Еще один человек закончил это руководство.
