Введение
If the cell phone is not charging correctly with different USB chargers, the charging port may be the cause of the issue.
Выберете то, что вам нужно
To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
Remove the six 1.5mm Phillips #000 screws from the bottom of the phone.
Use a plastic opening tool to disconnect the white and black antenna cables from the daughterboard.
2 участников успешно повторили данное руководство.
