Введение
Make sure that the device is unplugged and removed of all contents before starting this repair. Also be careful when removing and inserting the Heat Plate.
Выберете то, что вам нужно
Grab the handle and pull up to remove the top container.
Set this piece close by as you will be needing it for a future step.
Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
Once the screws are removed, carefully pull off the metal piece.
Once the piece is removed, you will be able to access the heater.
This step involves using the top contained that you put aside in step 3.
Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
Еще один человек закончил это руководство.
