Введение
This guide show use how to get to the power cord. One might find this help when repairing/replacing a faulty cord.
Выберете то, что вам нужно
This is what the bottom cover will look like. Flip the Brew Station upside down to easily access the screws.
Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
Using the Crown Bolt #8 Steel Spanner, unscrew the two 8-mm screws labeled in a orange outline.
Carefully slide off the bottom drip tray by sliding it out away from the Brew Station.
Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline. This will release the bracket that is holding down the large piece in the middle.
Using one hand, gently lift the large silver piece out of the base.
Once the screw is out, gently lift the white circuit board out of the base. This will be where the power cord begins, so you will now have access to the full length of the cord.
Еще один человек закончил это руководство.
