Введение
After using this guide you will have learned how to replace the motor to your blender. You will need to use basic tools and soldering to complete this guide.
Выберете то, что вам нужно
Remove the container from the blender.
Hold the blender and the container, then twist the container in a clockwise motion.
Turn the blender so the bottom is facing you.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
Move the motor platform to the side.
Lift up the motor and remove it from the blender.
2 Комментариев
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Que tipo de motor tengo que comprar?
