Введение
Replacing of processor base. Be sure the processor is unplugged before beginning.
Выберете то, что вам нужно
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Почти готово!
Заключение
