Введение
Replacement of the power cord. Make sure to keep the processor unplugged until finished with replacement.
Выберете то, что вам нужно
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
From the open base pull the motor straight out.
Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor and then rewire the new power cord to the motor.
Remove the two 12 mm screws using the #2 Phillips head screwdriver.
Remove plastic piece.
Remove the three 12 mm screws using the #2 Phillips head screwdriver.
Remove the plastic piece by pulling straight up.
Remove the power cord from the ground by removing the solder with the soldering tool.
Еще один человек закончил это руководство.
