Введение
The fix is needed when the motor is worn out and overheats when used. To replace the old motor for a new one a Philips screwdriver (2mm), Tri-head screwdriver (2mm) and a soldering iron are needed. Also, you will need a new motor.
Выберете то, что вам нужно
Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
This reveals the motor.
Lift the motor out of the casing.
Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
