Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn off the toilet water valve by turning the knob clockwise.
Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
Unscrew the hose from the T-connector by turning the knob counterclockwise.
Unscrew the T-connector from the toilet by turning the knob counterclockwise.
Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
Screw the T-connector back on the toilet by turning the knob clockwise.
Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
Еще один человек закончил это руководство.
2 Комментариев
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Same concern.
