Введение
We will gain access to the screen, enabling us to replace it with a new screen.
Запчасти
Детали не указаны.
Place Visor Edge face down.
Notice the tab connecting the flip cover to the back of the PDA.
Gently push tab forward.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove four 2.6 mm Philips screws that are on the sides of the frame.
Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
With the device flipped over, use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
Wedge the spudger in between the glass and the metal frame.
Slide the spudger down the length of the screen to detach from the frame.
With your hands, pry the screen up from the detached side, and the screen will pop off.
