Введение
If your Handspring Visor Edge is producing distorted audio or no sound at all, use this guide to replace the speaker.
To confirm that the faulty part is coming from the Handspring Visor Edge’s speaker, inspect the speaker port for debris that may be interfering with sound quality. A small buildup of dust can be removed using an ESD-safe brush or small dust blower.
Make sure your device is powered off before you begin.
Выберете то, что вам нужно
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
