Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Remove the four 2.6 mm Philips screws that are on the sides of the frame.
Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
