Введение
After getting into the Hannspree Hannspad SN1AT71, the Camera is fairly easy to replace.
Выберете то, что вам нужно
Use the metal spudger to press an opening between the screen and back cover.
The plastic tabs are located on each corner of the back cover.
Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
Slide the metal spudger around the casing to separate it from the inside of the tablet.
Flip the tablet over so the screen side is down after all the tabs are separated.
Remove the back panel by delicately lifting it straight up.
Grab hold of the red wire using the tweezers.
Desolder the red wire connection from the motherboard using the tip of the soldering iron.
Move the wire connection away from the motherboard.
Desolder the black and yellow wire connection from the motherboard by following the previous step.
Insert the flat end of the nylon spudger between the battery and the case.
The battery is connected to the tablet with an adhesive tape and will come free slowly.
Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
The two cameras are connected with one ribbon cable.
Zero insertion force connector.
Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
Еще один человек закончил это руководство.
