Введение
The Wi-Fi card provides a wireless connection to a network. If it fails, you may be left with no other option to connect the tablet to the internet.
Выберете то, что вам нужно
Use the metal spudger to press an opening between the screen and back cover.
The plastic tabs are located on each corner of the back cover.
Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
Slide the metal spudger around the casing to separate it from the inside of the tablet.
Flip the tablet over so the screen side is down after all the tabs are separated.
Remove the back panel by delicately lifting it straight up.
Desolder the black and yellow wire connection from the motherboard by following the previous step.
Insert the flat end of the nylon spudger between the battery and the case.
The battery is connected to the tablet with an adhesive tape and will come free slowly.
Identify the card and its connection to the motherboard.
The card itself.
The area where the card connects to the motherboard.
Еще один человек закончил это руководство.
