Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement
Выберете то, что вам нужно
  1. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Start: шаг 1, изображение 1 из 1
    • Empty the kettle and make sure nothing is coming out of the switch (some condensation is expected to escape from there)
  2. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Base plate disassembly: шаг 2, изображение 1 из 1
    • Remove the two Phillips screws (circled in red on the picture) and use a triangular bit to remove the third screw (circled in green on the picture)
  3. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Extracting the strip from the replacement control terminal: шаг 3, изображение 1 из 2 Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Extracting the strip from the replacement control terminal: шаг 3, изображение 2 из 2
    • I couldn’t find just the bimetallic switch, so I purchased instead a replacement temperature control terminal for another type of Kettle on Amazon. The strip appeared to be pretty standard and slides right out when you lift it from the bottom notch.
  4. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Replacing the strip: шаг 4, изображение 1 из 2 Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Replacing the strip: шаг 4, изображение 2 из 2
    • You can remove the old corroded strip from the kettle (red circle on the picture). Simply lift it from the little notch on the bottom (green circle on the picture).
    • Then you can slide in the replacement strip, with the middle metal tongue facing up. Make sure to slide it under the two plastic side guides.
    • When the water boils in the kettle, steam is sent through inner tubing down to the bimetallic strip. The strip will change shape with the heat, the tong will flip down, and trip the switch.
Заключение
4 участников успешно повторили данное руководство.
cortig
Участник с: 09/21/14
661 Репутация
1 руководство автора
5 Комментариев
Extremely useful and saved us buying a new kettle. Thank you!
Melanie M - Ответить
The part is not available on Amazon. Anyone know of another source?
Richard O'Brien - Ответить
found the part finally and worked perfectly. I contacted the company, they were nice but not much help. Everything is disposable these days based on the way companies treat and make products.
Hi there! Where did you find the part, Richard?
Morgan Curtis -
Yes curious what part you found...
Ethan Miller -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 12
За последние 30 дней: 54
За всё время: 1,916
