Введение
This guide will help you to replace the power port of Harman Kardon Invoke. You may replace the power port if you faced a weak port that will affect the efficiency of the Invoke or a broken/old port that prevents the invoke from connecting to power. By replacing the power port, the Invoke should be connecting to the power perfectly.
Инструменты
Запчасти
Детали не указаны.
Use a T10 Torx screwdriver to remove two 10 mm screws from the board that is attached to the ports.
Pull the board up lightly.
Еще один человек закончил это руководство.
