Harman Kardon Onyx Studio 2 Front Panel Replacement
Выберете то, что вам нужно
  1. Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: шаг 1, изображение 1 из 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: шаг 1, изображение 2 из 3 Harman Kardon Onyx Studio 2 Front Panel Replacement, Front Panel: шаг 1, изображение 3 из 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
  2. Harman Kardon Onyx Studio 2 Front Panel Replacement: шаг 2, изображение 1 из 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: шаг 2, изображение 2 из 2
    • Remove the five 14.4 mm T10 Torx screws.
  3. Harman Kardon Onyx Studio 2 Front Panel Replacement: шаг 3, изображение 1 из 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Front Panel Replacement: шаг 4, изображение 1 из 2 Harman Kardon Onyx Studio 2 Front Panel Replacement: шаг 4, изображение 2 из 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
Заключение
To reassemble, follow these steps in reverse order.
2 участников успешно повторили данное руководство.
Alexandra Achtenberg
Участник с: 02/02/17
2 046 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 16-5, Blackwell Spring 2017 Участник USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 членов
Автор 24 руководств
Один комментарий
Hi, I have the ONYX STUDIO with the silver ring that serves as the stand and the handle at the same time. After removing the front grill, I find the same five holes as it is shown on your pics but there are no screws. I can just see a bottom made of plastic. Do you have experience with that? Is that just some cover I can get thru using a screwdriver and I find the screws beneath?
I want to look inside as I am facing the problem with not working battery. As soon as I unplug the power source, it stops working.
Thank you for your comments.
Vaclav Matoulek - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 50
За всё время: 6,079
