Введение
If your speakers are busted or faulty, this guide will help you in replacing one or both of the speakers in your Onyx Studio 2.
Выберете то, что вам нужно
Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
Remove the four wires connecting the front and back panels.
Pinch the connector tab and pull gently upwards.
Repeat for the other three connectors.
Pull the silicone button band off of the outer edge of the speaker.
Gently remove the control board band by placing fingers in contact with it through the button openings.
Disconnect the remaining connectors from the circuit board.
Disconnect the Bluetooth antenna.
Remove the four 10 mm T10 Torx screws.
Pull the circuit board out of the device as it is now free.
Using the metal spudger, gently pry off the two red and black connectors.
Pull out the speaker, and if necessary follow these steps to replace the other identical speaker.
7 участников успешно повторили данное руководство.
2 Комментариев
Hi, do anyone know sparepart number for woofer elements?
Hello.. what is the wattage of the speaker? and where can i get a replacement. how much?
