Введение
If the game is turned on but the Bop-It button(s) does not work, this is because the button inside the device that provides functionality may be broken. To effectively replace them see this step-by-step guide.
Выберете то, что вам нужно
Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
Remove the buttons by de-soldering them from the wires they are attached to or from the mother board. Refer to the soldering guide here.
3 участников успешно повторили данное руководство.
