Введение
Use this guide to replace the levers inside the Hasbro Bop-It Micro Series game. The levers make the pull-it and twist-it handles function. When you pull or twist the handles, the levers push a sensor. The levers may be damaged if the game turns on but the handles don’t work.
Before using this guide, make sure to review the troubleshooting page.
Выберете то, что вам нужно
Loosen the two captive 8 mm screws in the back cover using a Phillips #0 screwdriver.
Remove the six 6 mm screws from the back cover using a Phillips #0 screwdriver.
When removing the final screw, hold the assembly together. There is a spring inside the device which will pop the assembly apart when all the screws are removed.
2 участников успешно повторили данное руководство.
