Введение
This guide will show you how to replace the Furby's light sensor circuit board.
Выберете то, что вам нужно
Use a flathead screwdriver to remove the two 10mm screws on the base of the Furby.
Use a Phillips #0 driver to unscrew the eight 10mm screws.
Remove the base ring after unscrewing all the screws.
Locate the two middle clips first.
Locate the two remaining clips on Furby's sides, they are opposite each other.
Orient the Furby upside down with the tail facing away from you.
Insert a metal prying tool directly into the clip opening.
Press upward into the clip. At the same time, use your other hand to pull away the plastic seam from the Furby's body.
Repeat the previous step to remove the remaining three clips.
Locate the two 10mm screws and remove them with the Phillips #0 head screwdriver.
Lift up on the fur covering until the face of the Furby is exposed.
Orient the Furby on its side to where the beak is facing left and locate the edge of the aluminum tape.
Lift tape gently and peel back until the tape is nearly removed.
Locate the four 10mm screws. Two on either side of body, and two on top of back plate, around the tape.
Remove the 10mm screws with the Phillips#0 screwdriver.
Peel the tape gently, grabbing it from the bottom edge and folding the tape upward.
Orient the Furby face down, with the base facing away from you.
Locate the clips below the ears.
Repeat the technique used in Step 6. Create leverage using a metal prying tool to press upward into the clip, while also pulling back on the clip itself.
Remove the loose, plastic back panel by pulling the panel away from Furby's body.
Remove the 10mm Phillips #0 screw holding the circuit board in.
Gently lift out the circuit board.
Orient the Furby with the tail pointing left and the face pointing right.
Use the pointed tweezers to spread open the socket, and the blunt tweezers to grip and tug out the connector.
Insert your replacement light sensor connector.
Еще один человек закончил это руководство.
