Выберете то, что вам нужно
Remove the stickers covering the screws. These are located on both corners of the screen. (Two in total)
Remove the two 7mm screws.
Use a plastic opening tool to pull the plastic screen bezel forward.
Remove the 4 7mm screws in the corners holding the screen up.
Use a plastic oping tool to pry the screen forward. Lay it on the keyboard.
Peel off the tape that connects the chord to the screen.
Carefully unplug chord.
Еще один человек закончил это руководство.
