Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Before beginning this repair, you should be familiar with soldering a circuit board. The soldering skills needed aren't very in-depth, but you'll be working very close to some other components.
Выберете то, что вам нужно
Place a small piece of tape over the Light button to prevent it from falling out in later steps.
Flip the controller over so the back is facing up.
Remove the battery compartment screw with a small Phillips screw driver.
Lift off the battery cover.
Remove the six AA batteries from the compartment.
Remove the remaining four screws with a small Phillips screw driver.
Flip the device over so the front is facing up.
Remove the front cover and place it to the left side.
Use the soldering iron and solder wick to remove the solder from the IR LED you're replacing.
Pull the LED out through the top.
Insert the new LED into the slot.
Use the soldering iron and solder to connect the new LED.
Еще один человек закончил это руководство.
