Health o Meter HDR743 digital bathroom scale - LED Display Replacement
Выберете то, что вам нужно
  1. Health o Meter HDR743 digital bathroom scale - LED Display Replacement, LED Display: шаг 1, изображение 1 из 1
    • Open front cover of scale.
    • Examine the edges of the LED display to see if there are broken or missing solder connections with the circuit board.
    • If there are broken solder connections, re-solder the existing display to the board and skip the remaining steps. Otherwise, the LED display needs to be replaced to correct display issues, so proceed with the remaining steps.
  2. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: шаг 2, изображение 1 из 1
    • Use a soldering iron to separate each of the connections between the circuit board and LED display. Once all of the connections are removed, pull away the broken LED display from the circuit board.
    • Remove unnecessary solder from the old connections so that each connection is separate. Leave a small amount of solder on the board to help make new connections.
  3. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: шаг 3, изображение 1 из 1
    • Solder several connections between the new LED display and the circuit board.
    • Do not let any of the connections touch each other or the display will not function correctly.
  4. Health o Meter HDR743 digital bathroom scale - LED Display Replacement: шаг 4, изображение 1 из 1
    • To reassemble, securely replace the cover of the scale.
    • Test the LED display by stepping on the scale. If there are still errors in the display, check your connections and repeat soldering steps if needed.
Заключение
Once reassembled and tested, if the new LED display does not work and no connection issues are seen, then it may be the circuit board. In that case, see Circuit Board Replacement.
Еще один человек закончил это руководство.
Travis Floyd
Участник с: 04/01/18
506 Репутация
Автор 2 руководств
Команда
University of Memphis, Team S1-G1, Kim Spring 2018 Участник University of Memphis, Team S1-G1, Kim Spring 2018
UM-KIM-S18S1G1
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 223
