Введение
Overly long pants will bunch up at the ankles, and may even drag along the ground or get caught under your shoes. (If you thought last season's styles were embarrassing, try tripping over your own pants.) Use this guide to avoid fashion faux pas by hemming your pants to suit.
For replacement parts or further assistance, contact Patagonia Customer Service.
Выберете то, что вам нужно
Begin by assessing the pants' current length. This is best done by wearing the pants along with an appropriate pair of shoes.
Fold the cuff of one pant leg inward, and adjust it to the desired length.
Insert two or three pins to hold the cuff in position.
The pins should be placed parallel to the new fold.
With the pins in place, verify that the length is correct.
Make any final adjustments to the length as needed.
On a flat, clean surface, lay the pants down on their side with the newly shortened pant leg on top.
Using a ruler, note the distance from the edge of the old cuff to the edge of the new cuff.
Repeat the measurement several times along the width of the cuff, making sure the new hemline is perfectly even.
Thread the sewing machine, using a thread color that matches your garment's fabric as closely as possible.
Place the first cuff on the sewing machine, and position the sewing needle between one of your pins and the edge of the cuff.
Gently depress the foot pedal and begin sewing.
Pause when you reach a pin, and remove it before continuing.
Continue sewing all the way around the cuff, until you reach the first few stitches.
Sew over the first few stitches to prevent the stitches from unraveling.
Raise the presser foot, and remove the pants from the sewing machine.
Clip any threads.
Turn the cuff over so that the extra length of the hem folds out.
Clip the extra length, leaving about a half inch of fabric beyond the seam.
Set your sewing machine to a zigzag stitch.
Insert the freshly cut edge of the hem into the sewing machine.
Lift the presser foot and remove the pants from the sewing machine.
Clip any excess threads.
Repeat steps 5-19 for the second pant leg.
6 участников успешно повторили данное руководство.
2 Комментариев
Perhaps a better idea: http://www.sewmuchado.com/2011/06/tutori...
Thanks for the post 2048
