Введение
The earpads play a crucial part in the active noise cancelling experience. Without them sound would be distorted. If yours are old or need to be replaced this is the guide for you.
Выберете то, что вам нужно
Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
