Введение
High heel elastic strap buckles get worn out after time with constant pulling and plugging of the strap. When the buckle loosens or breaks, it is unable to strap properly causing the heels to be unuseable. Instead of replacing the pair of heels, the strap buckle can be fixed with quick sewing.
Выберете то, что вам нужно
Cut through the remaining thread of the elastic strap.
Remove the strap buckle to adjust the position.
Slide the end of the strap underneath the buckle frame without the center prong.
Lift the center buckle prong vertically and place it into the center of the strap elastic.
Fold the detached elastic strap together with the strap attached to the heel so that both straps are evenly lined up.
With a threaded needle, sew along the ends of the straps in order to enclose the buckle in place.
