Hipstreet Titan 2 HD Rear Case Replacement
Выберете то, что вам нужно
  1. Hipstreet Titan 2 HD Rear Case Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Rear Case Replacement: шаг 2, изображение 1 из 1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Rear Case Replacement: шаг 3, изображение 1 из 1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Rear Case Replacement: шаг 4, изображение 1 из 2 Hipstreet Titan 2 HD Rear Case Replacement: шаг 4, изображение 2 из 2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Rear Case Replacement: шаг 5, изображение 1 из 2 Hipstreet Titan 2 HD Rear Case Replacement: шаг 5, изображение 2 из 2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Rear Case Replacement: шаг 6, изображение 1 из 1
    • Once the speaker is disconnected, the cover removal is complete.
Заключение
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Jeffrey
Участник с: 03/11/15
766 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-6, Panko Spring 2015 Участник Colorado Springs, Team 5-6, Panko Spring 2015
UCCS-PANKO-S15S5G6
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 590
