Hipstreet Titan 2 HD Speaker Replacement
Выберете то, что вам нужно
  1. Hipstreet Titan 2 HD Speaker Replacement, Rear Case: шаг 1, изображение 1 из 1
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Speaker Replacement: шаг 2, изображение 1 из 1
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Speaker Replacement: шаг 3, изображение 1 из 1
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Speaker Replacement: шаг 4, изображение 1 из 2 Hipstreet Titan 2 HD Speaker Replacement: шаг 4, изображение 2 из 2
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Speaker Replacement: шаг 5, изображение 1 из 2 Hipstreet Titan 2 HD Speaker Replacement: шаг 5, изображение 2 из 2
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Speaker Replacement: шаг 6, изображение 1 из 1
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Speaker Replacement, Speaker: шаг 7, изображение 1 из 1
    • Remove the black placement tape.
  8. Hipstreet Titan 2 HD Speaker Replacement: шаг 8, изображение 1 из 1
    • Using a #PH000 screwdriver, remove the three 0.145in circuit board placement screws.
  9. Hipstreet Titan 2 HD Speaker Replacement: шаг 9, изображение 1 из 3 Hipstreet Titan 2 HD Speaker Replacement: шаг 9, изображение 2 из 3 Hipstreet Titan 2 HD Speaker Replacement: шаг 9, изображение 3 из 3
    • Lift the hinge locks on the three ribbon connectors and disconnect the ribbon connectors.
  10. Hipstreet Titan 2 HD Speaker Replacement: шаг 10, изображение 1 из 1
    • Identify the two soldered connectors for the speaker.
  11. Hipstreet Titan 2 HD Speaker Replacement: шаг 11, изображение 1 из 1
    • Using a solder removal tool, remove the speaker soldered connectors.
    • Solder the new speaker wire connections to circuit board.
    • First solder the red wire on the left, then the black wire on the right.
    • Solder can burn you. Use caution.
Заключение
2 участников успешно повторили данное руководство.
Jeffrey
Участник с: 03/11/15
766 Репутация
Автор 5 руководств
Команда
Colorado Springs, Team 5-6, Panko Spring 2015 Участник Colorado Springs, Team 5-6, Panko Spring 2015
UCCS-PANKO-S15S5G6
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 9
За всё время: 313
