Запчасти
Никакие детали не требуются.
  1. Make sure that the laptop is turned off and disconnected from any power sources.
    • Make sure that the laptop is turned off and disconnected from any power sources.
    • Flip over the Chromebook.
    • Unscrew the screws with PH11 screwdriver.
  2. Remove the front two hub caps.
    • Remove the front two hub caps.
    • Pry the perimeter of the case with a plastic opening tool.
    • Remove the back panel.
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with a PH000 screwdriver.
    • Use tweezers to unplug the battery.
    • Remove the battery.
Заключение
Alexander Burrell
Участник с: 09.10.2018
355 Репутация
Автор 2 руководств
Команда
USF Tampa, Team S1-G3, Leahy Fall 2018 Member of USF Tampa, Team S1-G3, Leahy Fall 2018
USFT-LEAHY-F18S1G3
3 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 10
За 30 дней: 39
За всё время: 45
