Введение
Replacing the speakers is simple enough. All that is required is a plastic pry tool and a few
minutes of time. It is recommended to perform this procedure in a will-lit area, as there is not
much contrast between many of the components on this device.
Выберете то, что вам нужно
Using a plastic opening tool, carefully place under one corner of the battery.
Move around edges of the battery to lift it off of the tablet.
Remove battery from tablet.
Peel back the film holding the speaker wire in place
Detach both wire connectors
Using a plastic opening tool, carefully place under one corner of each speaker
Remove both speakers
