Введение
If the buttons on your humidifier aren't working, follow this guide to access the control panel. This will show a simple step-by-step process of how to remove your control panel for a replacement. For this guide, you will use a Phillips #1 screwdriver head to remove and replace the control panel.
Выберете то, что вам нужно
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
Remove the AC power plug cover.
Remove the remaining four 7mm screws that hold the bottom cover.
Remove the bottom cover.
Disconnect the two white cables by pushing down the center tab at the end and pulling it out of its socket.
Remove the three 7mm screws that attach the control panel to the case.
Remove the control panel from the case.
