Введение
If your humidifier is making loud noises or is not releasing mist, follow this guide to access the fan. This guide is an easy step-by-step process of how to remove your fan for a simple replacement. For this guide, you will need a Phillips #1 screwdriver head to remove and replace the fan.
Выберете то, что вам нужно
Lift up the water tank and separate it from the humidifier.
Flip the humidifier over to its underside.
Use the Phillips #1 screwdriver to remove the two 7 mm screws that secure the AC power plug.
Remove the AC power plug cover.
Remove the remaining four 7 mm screws that hold the bottom cover.
Remove the bottom cover.
Remove the 7 mm screw that secures the metal cover for the fan cable.
Remove the metal cover.
Disconnect the fan cable from the circuit board by pushing down the center at the end and pulling it out of its socket.
Remove the fan.
